Connect HPX371 with tv
Niels Neeskens
Hey everybody,
I am filming a training next week and have to record the sessions so that the participants can view themself right after the recordings. So my question is; what is the best way to connect my HPX 371 with my Sony Bravia to play back the recordings straight on the tv?
The simpliest way ist to use a BNC-Cable on Video-Out of the Camera. On the other End of the cable you need a BNC to Chinch Adaptor, which can be plugged into the yellow AV3 Connector of your Bravia (I think the most Bravias have this on the left side?).
The Quality is not good, But thats the simpliest way.
If you want better Quality, i think you need a HD-SDI to HDMI Converter.
Keep it simple and just connect via component if it is just for viewing, this is what I do and a bnc to phono cable is required.
I tend to keep a BNC to phono adaptor on the camera all the time and just use a phono to phono cable whilst on location as it is easy to rig and de-rig, also if someone stands on the cable it just pulls it out of the bnc adaptor rather than damaging anything.
You can go into the clip browser and easily play back takes and the quality should be fine for most viewing purposes, it's what I use on all shoots to a 14inch 4x3 TV so that we can see the full 16x9 frame and the quality is great, if my clients want full HD then they have to hire in extra kit.
If you want to go high def to the TV then you will need an HD/SD-SDI converter box as stated so that you can feed the TV with an HDMI signal from one of the SDI outputs.
