JVC says:
"When HD originals are intended for release on SD media, especially DVD, JVC recommends finishing in original native high definition, thereby preserving maximum image quality. Once completed, an HD project is easily output in SD for final release.The final DVDs will be of significantly better quality than if the project is posted in DV from an in-camera conversion.
Here's why: The HDV format records significantly higher resolution and the chroma is subsampled at 4:2:0. If a DV dub is made from an HDV recording, the extra resolution is lost, and the chroma subsampling effectively becomes 4:1:0. This is less than optimal for DV which records at 4:1:1 (in the U.S.), and less than optimal for DVD which utilizes MPEG2 at 4:2:0. Modern non-linear editing systems can edit the HDV recording in HD, and do any processing (extra enhancement, effects, etc.) in the higher resolution HD domain, and with the full HDV chroma resolution. The final DVD can be made from the NLE's downconverted output, but with the full chroma resolution and 24p cadence of the original MPEG2 recording. "
I don't get this. first they say HD will look better than footage shot natively in Standard def DV. but in the second paragraph it says that the extra res and chroma is lost and you end up with 4.1.0 subsampling which is "less than optimal for dv". isn't this contradictory? how can downsampled hd burnt to dvd look better if it's not even 4.1.1? I'm also confused that they seem to use the terms "HD" and "HDV" interchangebly.
