I played with one and couldn't get proper focus through the whole zoom range. I tried a couple different c-mount adapters as well, so I'd say don't bother.
Never used that lens but do own the 12.5-75mm 1.8 Pentax C mount w/kipon c adapter and it's a great lens for the GH2. in ETC granted it aint a 12.5 but likely a 44-300?. Love the lens, sharp, great bokeh, does weird things with light, solid build, great focus, had mine declicked. Might be my favorite new lens. Not cheap almost $300 at BH.
this fujinon looks worth a bid, some of the zooms need a slight mod as the c mount needs filing down. My Pentax fits snug on the kipon.
http://cgi.ebay.com/FUJINON-ZOOM-1-...74163137?pt=Camera_Lenses&hash=item3cb759f2c1
I got a generic c-mount to m43 adapter and it fit perfectly.
I have this lens and it works fine. You have to stop down a bit for sharpness/contrast, but otherwise it works fine in ETC mode.
None of these C mounts used for CCTV work unless they are very small 8mm types. You can use the Computar but you will have to cut off at least 10mm from the rear as I have done on a few lenses. These lenses do not fit unless you are willing to do some cutting and gluing basically like I have in this thread.
http://www.dvxuser.com/V6/showthrea...oom-lenses-and-CCTV-lenses-on-the-M4-3-system
Thanks for your information. The Pentax is of course a well made quality lens without doubt. I have an Angenieux 2.2/12-120 mm on my GH2. A fine lens, too, which works great. But it is littly bit bulky and I need a bridge for its weight (ca 900g). Fine for tripod use. No run and gun combo. (Too long tele-focus.) So I am looking for a shorter, lighter and specially faster zoom.
The questions is, if the very fast and relatively cheap zoom lenses (cosmicar etc with an aperture of 1.2) are usable in concern of their picture quality?
Thanks for the ebay-link. I am not shure, if I shall spring into the cold water. As long as the item stays cheap no problem, although the shipping (I am living in Germany) and the duties highens the price.
Why have you bought the pentax with an aperture of 1.8 and not with an aperture of 1.2? What were your considerations? Thanks.
I use the kipon c mount, all my Pentax CCTV lenses work just fine, perfect fit to GH1/2 and AF100.
I use the kipon c mount, all my Pentax CCTV lenses work just fine, perfect fit to GH1/2 and AF100. I own 12.5mm 1.2, 25mm 1.4, 12.5-75mm 1.8 all fit. Obvious vignette issues with lenses to GH1 and AF100.
