Hi,
I’ve tried to export using Compressor, and when I hit submit, it goes thru the processing bar (in history window) then says failed. I've done it several times and did the whole setup twice. I have used this method several times on very similar projects and no problem. Anyone guess what it might be?
I have noticed that the AC 3 files have been stored on my desktop, so I guess something in the video portion failed. Also I tried the QT method and at the end a general error window pops up. When I go to the job window to select it I see it hasn't registered. I don't know if this helps.
Thanks again.
George
Thanks again.
George
