Barry_Green
Moderator
limo991 said:I like the disclaimer. I wouldn't be able to that even if I I triedLets keep comparisons realistic.
Was this or was this not about HDV artifacts? The FX1 shots are HDV artifacts. How's it not realistic?
Barry_Green said:Was this or was this not about HDV artifacts? The FX1 shots are HDV artifacts. How's it not realistic?
You can have the entire FX1 stream. I'll dig it up and upload the whole thing. So you can see every frame with and without any explosions and everything.limo991 said:So, the quality dropped for a few frames. The area on the right is entirely black on the HVX so we can't really compare anything. Can we have an FX1 frame without an explosion or an HVX frame with an explosion?
Simple enough to fix. I removed the HVX picture and instead put in a shot of the FX1 without the macroblocking. I found a spot in the stream that looks comparable to that HVX shot and substituted it out.limo991 said:If you had only posted the Fx1 frame I bet nobody would say anything.
limo991 said:
I extracted the frame at pixel-for-pixel basis. But, they were upsampled to 1920x1080. Maybe that's the difference you're seeing.limo991 said:Barry, is it possible that the HVX example is 1:1 pixel but the FX1 sample is zoomed in by 200% or something? The Fx1 frame is already much larger, so why zoom? The FX1 actually compares with the HVX at similar lighting.
That's also what I was trying to point out with the HVX image -- this is what it's supposed to look like. I guess I just did the wrong thing by showing an HVX frame of it.myfriendimage said:That looks way more close to what I was thinking. I was expecting the HVX to win over the Fx1, but it made the fx1 look lik an old Hi8
I can find that clip. I'll root around on the Mac and see if I can find where it is.limo991 said:I would love to see even a compressed version of the HVX. Mostly for seeing how it overexposes. I know the detail on strobe light will be better than HDV.
limo991 said:The frames I posted are normal everyday frames and that's what I see on HDV. Your frame has an explosion and actually compares to HVX in entirely different exposure. That's what I meant. It is a HUGE exageration! The cameras are very close in typical situations.
Fine -- but would you also care to add the text I had when I posted that picture? Where I said specifically that it was to show what the detail was supposed to look like, and that I didn't try to find a matching frame but instead I looked for one where there was enough light to show the detail?xray said:Your new comparison is better, but to help understand this thread, I think it is ok to post your original in again.
http://static.flickr.com/41/100485297_c3c37b5c19_o.jpg
