swiperstopswiping
What is the best way/program to compress video footage from the DVX100?
Jack Daniel Stanley said:Codecs
Shooting and rendering 24pa also helps reduce file size as there are fewer frames to render vs. 29.97 even though you are getting full frame rate.
If you don't mind, would you be so kind as to give me a brief explanation why 24p would be better if the final output was tape?Jack Daniel Stanley said:Only reason to shoot 24p as opposed to PA is if your final output is tape.
