Component Output question...
My last component cable for my 170 is bust...I've been looking around and can't seem to find that specific cable.
I think it's called a "mini-D" component cable.
The monitor that I'm using is the Manhattan LCD HD089B. It has HDMI, regular component, and VGA inputs.
The HPX-170 has RCA, SDI, and that "mini-D" outputs...can anyone recommend the ideal cable/adapter for this setup?
Thanks in advance.
That cable is used by lots of different cameras, including the HPX170, HMC150, HMC40, and I think at least some JVC models use it. You should be able to pick one up from Spec-Comm, an authorized repair center.
Definitely not. The HVX200's component connector is very different. The HPX170, HMC150, and HMC40 all share the same.
The HVX200 and HPX500 share the same as each other, but very different from the others.
