Component output problem
Overlook
I am using the component output on my HVX for the first time and I am having a problem.
I have the component cable that came with the camera connected to the camera and I have the red green and blue strands plugged into the back of a Sony CRT monitor that has RGB input.
I have the monitor set to sync on green.
I have the camera set to output color bars.
The signal I get is overwhelmingly green. If I disconnect either the red or the blue only a slight variation appears in some areas of the screen.
If I have only the red or the blue attached the image is unsteady.
Any idea what's going on?
Is the output of my camera broken?
I get a good image using SVHS.
Thanks.
The camera only outputs a component Y, B-Y, R-Y signal. It will not support RGB output. Perhaps this is the issue? You may be able to switch from RGB to Component in the monitors menus.
I hope this helps. :)
Best regards,
Andrew Hoffman
Vice President
Specialized Communications Corp.
20940 Twin Springs Dr.
Smithsburg, MD 21783-1510 USA
800-359-1858 (US)
301-790-0103
Fax: 301-790-0173
andrewh@spec-comm.com
www.spec-comm.com
Please visit our new online store at ( http://www.spec-comm.com/store ). New products being added daily!
