Component out Question on FS700
Eaglei23
Hey all,
I have a SD 16:9 monitor that came with my varizoom aviator steadicam rig and I was curious as to why the component out on my FS700 is not sending a video signal to the monitor?
The monitor works fine with my Panasonic HMC 150, but I'm curious as to why after even tinkering with some settings on my FS700 there is no signal going to the monitor? Could it be some technical reason with HD-SD conversion I am unaware of?
Thanks!
Ryan
Is it component or composite? Usually steadicam SD monitors are composite, perhaps that is the confusion?
Following up on nyvz's question, if you are in fact trying to send a non-HD signal to your SD monitor, you will need to go into the camera's settings and change the output resolution to SD Video, which will turn ALL your outputs to SD, including your HDMI and SDI.
I've also had some intermittent difficulty getting a component signal out of my FS700 (if you ARE talking about component). I have an HDMI on-camera monitor and attempted to use a long component signal into a 24" LCD TV as a client monitor only for the TV to get no signal at all. I still don't know what caused that, as I used the same setup at home to a different TV over component without incident.
