Complete offload from the DVXuser shop?
Pascal Parvex
When a good, cheap offloading solution for the DVX is found, will it be offered as complete solution in the dvxuser shop? Because I don't know which casings will do the job and which won't.
And how do you shoot continually with two P2 cards? I mean, after the transfer you still need to format the card. Is this possible without accessing the HVX menu?
The P2 Store is a one-man-band attempt to solve that; it quaffs the cards and formats them all automatically while being strapped on your belt.
Seems expensive for a 60gb drive, but considering that it does things nothing else does, you have to look at it in context with your workflow and see if it makes sense.
For those of us who can make use of a laptop, you'd quaff the cards in the laptop and then format them there. That would give you access to much more than 60gb of space, for a lot less money, but obviously that's not quite the same as a belt-mounted fire-and-forget type of solution like the P2 Store is.
