gordonfuller
COMPLETE CINEMA MATTEBOX, FOLLOW FOCUS, 16x9 LENS, FILTER KIT: DVX-100/A & CANNON XL2
COMPLETE WIDESCREEN CINEMA KIT
These components are in excellent/mint condition without any signs of use, mechanically and cosmetically perfect. Purchased from EVS in 2005 by professional cinematographer. Ideal for filmmakers seeking the widescreen motion picture look.
INCLUDES THE FOLLOWING:
CHROSZIEL MATTEBOX SYSTEM 411-53PK
Chrosziel 411-53PK ProMatte Mattebox System has professional features cinematographers request -- including a housing that covers both 16:9 and 4:3, , a French Flag, a 16:9 mask and, lightweight support & center bracket. For both handheld and studio work,.this mattebox will solve the shading and filtering problems previously experienced wusing front-mounted lens accessories on Panasonic AG DVX-100 cameras.Chrosziel's 411-53PK Mattebox system has features which include a housing that covers both 16:9 and 4:3, a French flag, a 16:9 mask, a provision for sidewings and a filterstage for two 4x4 filterholders - one fixed and one rotating. To ensure a secure mount, the system includes a lightweight support, mattebox rods, and a center bracket.
CHROSZIEL DV STUDIO RIG FOLLOW FOCUS SYSTEM 20601S
Specially designed for DV camera lenses equipped with gear ring. Small and lightweight. A white Delron disk allows erasable marks for accurate, repeatable focusing.Studio Rig mounts on lightweight support via the mounting bracket built into the unit The rectangular hole accepts whip and crank controls.
PANASONIC ANAMORPHIC 16X9 LENS ADAPTER AGLA7200G
Panasonic 16x9 Anamorphic Lens Adapter for the AG-DVX100 produces the wide screen effect seen in panoramic movies. Fully zoom-through even at f2.8. It screws into the 72mm threads and has a swiveling base with lockscrew to allow alignment. Some international broadcast channels (including the BBC), no longer will accept 4:3 aspect ratio productions for broadcast. This lens adaptor is designed to map perfectly to the DVX-100A’s CCD pixel array.
CENTURY OPTICS ANAMORPHIC VIEWFINDER CONVERTER VS-WSEP-DVX
VS-WSEP-DVX is a widescreen eyepiece for the Panasonic AG-DVX100 series of cameras. It allows viewing of a normal (unsqueezed) image when shooting with a 16:9 optical anamorphic attachment or the squeeze feature in the AG-DVX100A. The adapter slips onto the camera's existing finder and locks down with one lock screw. This converter is essential for a complete 16:9 solution.
SCHNEIDER OPTICAL FILTERS
The Chrosziel mattebox filter stage supports two 4x4 filter holders, one fixed and one rotating. The ND 3 and CP filters were used once, all others are unopened:
The following Schneider filters are included:
4X4 ND.3 FILTER 68050544
4x4 ND 0.6 FILTER 68040644
4x4 ND.0.9 FILTER 68040944
4X4 CIRCULAR POLARIZER 68013144
4x4 UV HAZE FILTER 68124144
4x4 81-ONE SKINTONE ENH 68-108044
CHROSZIEL FOCUS DRIVE 206-12
Chrosziel focus gear drive for cine style lenses. Allows connectivity between a follow focus wheel and the lens' manual focus teeth. Works with Chrosziel follow focus systems for Leica, Canon, and Fujinon cine style lenses.
CENTURY OPTICS MANUAL FOCUS SYSTEM VSMFSYDVX
Manual Focus System mounted to the Panasonic AG-DVX100 lens. Precision manual focus system for Panasonic AG-DVX100 series camcorders, provides accurate and repeatable focusing. Also included is an industry standard-pitch follow-focus gear to facilitate integration with popular professional cine-style follow-focus systems. User-markable white Delrin focus scale and witness mark that facilitate accurate and repeatable focusing.The unit simply clamp mounts over the lens' existing focus scales, no lens modification required. The effective lock-out mechanism limits the lens' focus range to 3-feet to Infinity with hard limit stops.
The following are original purchase prices:
Mfg./Product Description Mfg. Model # Price
CHROZIEL ProMatte Mattebox 41153PK 1685.95
CHROZIEL DV Studio Rig 20601S 1362.95
PANASONIC 16:9 Lens Adapter AGLA7200G 829.50
CENTURY OPTICS VF ADPTR VSWSEPDVX 335.90
SCHNEIDER 4X4 ND.3 Filter 68040344 164.95
SCHNEIDER 4x4 ND 0.6 68040644 164.95
SCHNEIDER 4x4 ND.0.9 68040944 164.95
SCHNEIDER 4X4 CP 68013144 235.50
SCHNEIDER 4x4 UV HAZE 68124144 145.25
SCHNEIDER 4x4 ND 3 68050544 174.95
SCHNEIDER 4x4 81-ONE SKE 68108044 145.75
CHROZIEL Focus Drive 20612 86.95
CENTURY OPTICS Gear Ring VSMFSYDVX 317.50
Total: $5,815.05
All items were purchased new in 2005 from EVS (great outfit, highly recommended by me).
XL2 setup for 16:9 shooting with the Chrosziel Mattebox.
According to 16X9INC, the Chrosziel 411-53PK mattebox will work with the XL2. You need extension rods model number 401-83, 100mm/4 inch extensions, along with another part that Chrosziel is manufacturing just for the XL2. Because the XL2 sits a tad higher than the AG-DVX100, Chrosziel has a new camera plate, model number 401-43-01, which is where the XL2 is fixed to the rods system.With these two parts, you should have a great mattebox, one with a 16:9 guide and compatible with many of Century Optic's lens adapters. Plus, if you already have one for the AG-DVX100/A cameras, you can switch between the two quite easily.
411-53PK and HVX?
I am unsure about the possibility of using an HVX with the Mattebox. Some have said it works using an adaptor plate to go from the square anamorphic to a 85mm ring. This adaptor is included in this kit from Chrosziel.
Google these products and compare prices, email your questions directly and/or make an offer. fuller.gordon@gmail.com
Total: $5,815.05
411-53PK and HVX?
