Nirv
Carbonite Member
The idea that there is only marginal difference between 50/100Mbps XAVC and 200/800Mbps Prores seems like a matter of different perspectives.
It's knowing that the FS5 and FS7 RAW output is 12bit Linear which nobbles you from the very start and is no way equivalent to the output of higher end cameras. At worst you get horrible noisy banding in the darks tones at best you're limited in dynamic range so the better codec doesn't necessarily help.
