The new Panasonic Color viewfinder for HD cams is about $8500 so most will find it not worth it to put on an HPX-500 even if it works.
The output of the VF plug is BW only, it will not support a color viewfinder. You can however use a small hd LCD screen mounted on an arm to use as a viewfinder. just detach the VF and place lcd there. Plug into one of the outputs on the back of the camera.
