Denniscasey
Still learning to use HMC40 while on vacation (agree its not the best way to learn to use new camera). To reduce risk of my errors I have generally left camera on full auto. While panning north to south on beaches with ocean surf crashing on rocky outcroppings (sun at back) I sometimes see color shifts in some portions of scan--I can only see these shifts while viewing shots at days end on high def TV so can't correct in the field while shooting.
I assume color shifts due to ATW (automatic tracking white balance) trying to adjust to different light conditions. I know for best results I should manually set white balance but because scenery I am viewing is far away I can't use technique Barry suggests (have subject hold white card and balance on that light). I also don't have a lot of time to do a lot of manual adjustments.
Under these conditions which approach will give me best chance for accurate stable white balance: (1) initially let ATW set white balance and then use ATW Lock to hold that white balance setting throughout panning shot or; (2) manually set white balance at beginning of shot if I have time and use that setting during pans?
I have to say my old VX2000 seemed to automattically manage color better than HMC40 (which is why I never learned manual white balance setting techniques) but maybe high definition which is great with HMC40 makes color setting more noticeable.
Thank you, Dennis
Thank you, Dennis
