Clouds timelapse
speedbump
http://dvxunleashed.org/clouds.html
Quicktime, 12.8MB, ~ 2 mins
Details:
24PA, F9.6, 1/8 ND. UV filter and polarizing filter in place.
4:3 aspect ratio, masked to 1:85 in post, otherwise uncorrected.
Vegas 4.0e, sped up 9X.
Saved with Sorensen 3 compression, keyframe very 240 frames.
Needs an orchestra. :D
This was kind of an interesting weather pattern. What you see is two layers of clouds, the upper layer getting sucked north-west by a looming storm system off camera, the lower layer barreling east and getting ready to dump free water on my lawn.
Re: Clouds timelapse
Speedbump,
I would probably speed it up significantly. The movement of the clouds can be so interesting when it is tearing across the sky. As it is, it doesn't look like a timelapse as much as it looks like regular time on a windy day.
Just my 2 cents.
so this isnt really time lapse? you just sped up the image? Like this isnt 1 shot every 30 seconds or something is it? Im curiouss what the difference would be if this is the case in the end product. Would it be jerkier?
Yes, it would be way jerkier and you would have to compensate for that jerkiness by using frame blending and speeding it up significantly.
disjecta-
You are probably right. I just wanted to kick something out and get it posted; I am fascinated by cloudscapes. Nice Marymoor footage BTW!
daberman-
Hmm, I hadn't really thought about the difference between true timelapse footage (the camera takes a frame every so often) verses merely speeding up the footage. I don't have any idea if timelapse would be jery or not. But, isn't speeding up the footage equivalent? I assume Vegas has to only take 1 out of so many frames of normal speed footage to speed it up.
I think this is nice, although it looks like slightly compressed time, with no real lapses.
It would make a great back drop for titles.
speedbump,
well the reason I asked, is that I want to film something that will take longer than 60 minutes to complete (like a chia pet growing) or something, otherwise, i'd just speed up the film.
I liked it, though I have to agree: speed it up a lot. I'm not clear on the specifics on how, but I'd say pick a fairly windy day with low cloud coverage and shoot it, I've seen low cloud coverage right before a storm move faster than your clip, so it wasnt immediately apparent to me that it was time lapse. but anyways, I liked the clip anyways, so keep it coming!
timelapse (0.5 secs every minute or so) need much longer to appear fluent. in the course of a day that is the way to go, but on shorter periods you can just roll the tape and speed up later.
