B Big_Stein Active member Dec 31, 2005 #1 I am making a Football highlight video. So I have a massive amount of clips in my Project Media window. Is there anyway to notate that a clip has been used in the timeline?
GenJerDan Veteran Dec 31, 2005 #2 It already is marked. The first column (unless you've rearranged them) is the number of times it has been used.
Sol M. Veteran Dec 31, 2005 #3 Right, and just to clarify, you'll only see this column if your Project Media view is set to "Detailed". The column is called "Use Count"
