Justin_Kirch said:doesn't any search for info on this forum???
a2zproductions said:What about the overal 24p look? If you shoot 60i (or video look)
and slow it down, will it not look like videoish...but at a slower speed?
How do you retain the "filmic" look and slow it down?
Thanks,
Adrian
Norbert said:How do you people do when you mix slow motion shots (interlaced) with progressive shots?
I tested this today.
I shot two clips with my DVX (PAL). I shot one clip in 50i with a 1/120 shutter speed and one clip in 25p. Then I imported them both into a progressive project (No fields) with a 25fps timeline. I slowed down the interlaced footage to 50% and left the progressive footage as it was. Then I exported the two clips with No fields, and I did not deinterlace anything. The slow motion footage looked awful, or should I say extremely jumpy? The progressive footage looked nice of course.
Then I imported my two clips into an interlaced project with a 25fps timeline and did the same thing. Slowed down the 50i clip to 50% and left the progressive footage alone. I then exported the timeline again, but this time with Lower field first. Notice I did not deinterlace anything this time either. Both clips turned out fine anyway. How come I don't have to deinterlace? And when I export with Lower field first, does that affect the progressive footage at all?
So, when I export for the web or the computer I guess I should export with Lower field first even if I have progressive footage in there?
But how do you people do when you want to burn a progressive DVD with some slow motion shots? If I burn progressive, will the slow motion footage be affected the same was as when I exported with No fields?
So just slowing the footage down and interpreting it to 25fps is not enough? The problem is I'm on a PC, using Premiere. Wouldn't exporting the footage to 50p and then bringing it back into the NLE result in a quality loss? Isn't there any way of doing this without having to export the slow motion footage before using it? Premiere is by the way unable to export to 50fps.Loki said:What you may need to do first is take your 50i file and export it to a 50p file first, the cinema tools route my not work precisely as I suggested if it is interlaced.
dcsimpson said:There are other ways to get good clean slow mo as well in 24P. I use REvisions Twixtor.
