Cini D or Cini V
...............And a different look for how much you want to spend messing with it later.
care to explain?
Cine D holds up better with a bunch of correction. Although it doesn't provide some of the richness you can get in camera using Cine V. If I know I'm going to be using a clip with a bunch of others under different light and different settings, I'll use Cine D. If I know I'll have a complete enough 'set' from one location, I use Cine V.
I rarely stray from those two.
Whats the reason for B. Press aside from the fact you like it, what does it do that amazes you that cini v or cini d can not do.
B Press is the least noise y of the scene files, especially in the blacks. Also, requires less light to get exposure because the dynamic range is not squashed to prevent overexposure like cine D and V. You'll notice the whites turn grey in cine D and V especially outside. You will get more blow outs in B Press but that happens on any video camera so you just have to deal with it.
Also, B press is kinda that standard HVX look because a lot of people use it. I used to use Cine D but I won't anymore after I started using B Press.
I think I have just been sold on B-Press, I hated the grain I was getting with Cini D, I thought it was better with the Cini V but it wasn't much better.
I'm going to set my settings to B-Press.
There is a setting with sharpness; however there is two tabs for sharpness should I adjust both or one for soft film like look.
Just use the standard scene file 4 that is on your camera. Its good as is, if you want to change some things maybe drop the pedestal one or two points max, depending on your look. I usually just leave it alone.
Detail level is what you want to adjust if you want to get rid of the harsh video look, are you using a 35 mm adaptor? Usually the 35mm lens softens the image up enough. V detail is for sharpening the detail between horizontal elements. From barry greens book: "Detail level works with edge enhancement, perhaps artificially drawing outlines around objects to accentuate their edges, v detail level works with the existing image, accentuating vertical contrast between horizontal elements."
I'm not sure if this applies to the HVX or HPX, but on the trusty old DVX Cinelike D and V both apply 3db of gain to the ccds. That gives you a half stop boost in the shadows at the expense of blowing out highlights prematurely.
