Cinevate Durus follow focus review
3xm
Let me start by saying that this follow focus is simply amazing. It is really well built and designed professionally. The precision of the gear box is amazing and I can honestly say there is no noticeable backlash. Quality wise, this is in par with other ff that cost twice as much! This is simply the best indie follow focus there is out there….heck, I don’t even consider it an Indie item, for me, this is professional grade!!!!….I have no problem (or shame) using this FF on high end shoots (along with an Arri one on our second cam)…that’s how good it is. How does it compare to an Arri FF you may ask?..... well it’s little hard to compare as they are designed differently….but as far as the precision of the focusing and gear box quality, I say it’s pretty dam close. (arri still being top of the line…no doubt…but it comes at a high cost! ;-) )
This FF can be mounted left or right (switchable), mountable on bottom or top rail (very handy!), comes in 15mm or 19mm, can fit a variety of lenses, has an adjustable angling of the knob (but not of the gear)…and to a certain extend, is high adjustable……now it’s not height adjustable in the true meaning of it…the gear and gear box do not change height …but instead you change height by angling the unit…it’s limited but it works for most situations.. While not an Arri replacement, (and I don’t believe they intended to be), this is a very worthy investment…especially for those of you budget conscious… I would seriously recommend anyone to take a hard look at the Cinevate Durus before purchasing your next FF. More details are available at www.cinevate.com
Let me know if you have any questions….
I just realized found this via a search. I've never seen the Nikon/RED combination posted before..so thanks for posting the pics.
Cheers,
Dennis Wood
nice review & pics!
how is the weight tho?
have you had a chance to use it with a dslr? can it get front heavy?
Crazy zero backlash.. looks to be built like a tank.
A trick I do to increase the clearance of a lens is to add a circular metal lens hood or extension tube to the front of a lense, increasing the distance I can mount the mattebox away from the cam. Of course this may not work to well with wide angle lenses.
