[FS: General] Cinevate Atlas 30 Linear Tracking System (Pegasus Heavy Lifter)
jamesc
Price: SOLD
Includes the following:
  • The Atlas/Pegasus Standard 3/8" Stud Plate
  • The 100mm bowl adpater
  • Two 35" (89 cm) chromed steel rods/rails
  • Two aluminum blocks which house the rails and can be mounted on a tripod or sit on any solid surface.
From Cinevate's web site: The patent pending Atlas 30 uses 5/8" chromed steel rods and a body precision machined from a single block of aluminum. It was developed in collaboration with the studio crew from Stillmotion.ca to meet their needs for rapid setup, rock solid stabiltiy, silky slow movements, light weight and compactness for air travel. The system is designed for ultra-smooth movements on loads up to 30lbs using long even long focal length lenses, and will accept heavier loads up to 45lbs with no complaints. The system uses highly advanced steel ball bearings. It can be broken down by hand for easy transport.
I purchased the Atlas 30 LTS from Cinevate roughly six months ago. It has only been used twice and I don't find that I use it as much as I wanted to, so I'm planning on selling it to buy some new lenses. This dolly/tracking system is rock solid. Everything is in mint condition. This not only comes with the stud plate, but the 100mm bowl adapter as well. Cinevate sells it for $1290.
For more details, please Cinevate's web site for more details - http://www.cinevate.com/catalog/product_info.php?products_id=109
Product Video: http://www.cinevate.com/website/flash/pegasus3.f4v
