andersonnd
Camera Mount Complete Package
This is near mint condition CineMount from CineTools. Everything you see in pictures is included except the camera. Works perfectly, these are built to be extremely rugged and should last for a very long time. Never abused and stored indoors, this is a great chance to save a lot of money on like new equipment.
Very hard to find this equipment in like new condition at used prices. Rarely will you find this on eBay. New this costs close to $600.
Listing is here: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=251246980242
Includes
1 Camera mounting platform 1
1 Low profile Manfrotto camera leveler 1
1 Quick release camera plate 1
3 Grip Heads Avenger with rubber grips 3
3 GOBO's Avenger with rubber grips 3
3 Vacuum cup with integrated pump and protector
3 2' Stainless Steel Rods
3 1' Stainless Steel Rods
Single cup load
70 lbs max
3 Cup cumulative load
210 lbs max
Low profile camera leveler load
33 lbs max
Camera bolt size included
1/4 x 20 & 3/8 x 16
Setup time Less than 10 min
Weight with no arms
10 lbs
Weight with 1' arms
11.1 lbs
Weight with 2' arms
12.2 lbs
Manufacturers description:
CineTools Cinemount 3045 Camera Mount - 33lbs. Ultra reliable 3 cup temporary camera mount for any smooth, nonporous surface. Will support cameras up to 33 lbs. The modular system allows infinite camera mounting positions and the flexibility to custom configure the mount to meet the requirements of those challenging shots.
Do you want endless camera mounting options? Want to capture truly remarkable camera perspectives to make the viewer feel part of the shot? The Cinemount 3045 provides a reliable, temporary camera mount on almost any smooth, nonporous surface, such as metal or glass.
The modular system allows infinite camera mounting positions and the flexibility to custom configure the mount to meet the requirements of those challenging shots. Included are 3 x one, two and three foot arms that can be used in any combination at the same time. You will capture truly remarkable perspectives and make the viewer feel as if they are a part of the shot. The ultra reliable Cinemount™ is custom designed and engineered with high-quality, durable components to last a lifetime. The quick setup (less than 10 minutes) and big studio results has made the Cinemount 3045 the choice for independent studios, all at a price that's making the rental houses frown.
Vacuum Cup (not suction)
The vacuum cup employ the force of atmospheric pressure to grip a surface: When a vacuum exists between the cup and the surface on which it is attached, the weight of Earth’s atmosphere holds the cup in place with incredible force. Unlike suction cups that produce a vacuum as they pull away from the surface, this vacuum cup uses a hand-actuated pump to efficiently remove air from between the rubber pad and the attaching surface thus creating a much more reliable hold.
Safety
The vacuum cup’s pump features a plunger with a red line, which serves as a visual vacuum indicator. This safety device is recognized as one of the most reliable warning systems available. A few strokes of the plunger seal the cup securely to the attaching surface. When the cup is attached completely, the plunger stops moving and the red line is hidden within the pump. A visible red line indicates that air has leaked back into the pad, making vacuum insufficient to use the cup. The cup has a built in air filter to keep impurities out of the pump and also comes with a plastic cup protector for when it is not in use. We always recommend the use of a safety tether on all camera mounts.
Built with Monfrotto / Avenger components and leveling system topped off with 5/8” stainless steel rods and filtered vacuum cups, quality came first.
Includes
Single cup load
70 lbs max
210 lbs max
33 lbs max
1/4 x 20 & 3/8 x 16
Weight with no arms
10 lbs
Weight with 1' arms
11.1 lbs
Weight with 2' arms
12.2 lbs
Safety
