Cinetactics Matteblox
Jim_Miller
Greetings fellow DVX100 lovers!
I will be reviewing the Cinetactics Matteblox mb100m setup for another major technology site, but after spending a full day with it, I wanted to share my experience with you guys first.
First off, when you consider the cost of all your equipment, the Matteblox is dirt cheap. So go for the whole package right from the start, otherwise you will kick yourself later. I believe they are still running a special for our group, so you really should invest in it now.
I have to admit that in the looks department, the Cinetactics package doesn't quite stack up to those astronomically-priced setups, but once you start using it, you'll forget all about the looks. Other than a bit of a tussle getting the lens shade onto the 72mm threaded adapter (a must-have!), it was all smooth sailing. The whole system is very functional, and as we know, velcro will outlive civilization as we know it. The filter holders are really practical if you live in a major city where you can actually rent pro 4x4 filters. They slip right in and hold firm. In fact, I doubt if any amount of mishandling will knock them loose.
The standard French Flag is pretty cool, and will probably work just fine about 95% of the time, but I do recommend the Oversize French Flag, as you are will almost never have to worry about flare unless you are actually looking to use it creatively. And while the Cinetactics people are hard at work on a matte box for the Panasonic Anamorphic lens (which is another "must have"), the oversized French flag can be used pretty easily until the real thing arrives. I use standard black gaffer's tape to wrap it around the lens and it works quite well. In all the footage I shot today (I keep thinking about all the hours I am putting on the heads--groan), I never had the slightest hint of flare in any shot, whether I used the standard Matteblox on the normal lens, or the anamorphic converter with the oversized flag.
Since this is a real value package, you might think the company would skimp on the extras, but they don't. All items come with convenient carrying cases. I had to do some mental gymnastics before I could fit the oversized flag into its case (there's a flap on the flag that must be folded down), but everything is now sitting in my camera case, ready to get back to work.
I hope this helps if you have been considering the Matteblox and wondered if it is "pro" enough. At a bargain price, the Matteblox products perform perfectly. I'm thrilled by the results and I'm pretty sure you will be, as well.
Jim
Re: Cinetactics Matteblox
Thanks alot Jim. Always good to hear a 2nd opinion. I am still waiting until the anamorphic accessory comes out from them before I purchase the whole nine yards.
Thanks, too , Jim - for sharing the info. and taking the time. Will probably also wait to look at the upcoming piece. :)
and a mattebox is something everyone needs :)
I've had the matteblox since it first came out and it's been sweet. The oversized french flag is a beauty I still haven't got yet. Good the hear the 4X4 filter set-up works.
What item is everyone getting for the DVX with stock lens?
Is there a link to use from the forum? Is there a special forum member price?
There is a member special. But how much of a member do you have to be? and how do we get it?
thanks.
btw, are all square glass filters universal in size? Because I noticed that cinetactics don't sell filters... probably a stupid question but I have no idea. if someone can enlighten me... thanks.
No, not all square filters are the same size. There are 3x3", 4x4", 6x6", Cokin A, Cokin P, Cokin Z, Cokin X-Pro, all sorts of different sizes...
