*.m2ts and *.mts on Panasonics are exactly the same h.264 video in the exact same MPEG2 transfter stream. Exactly the same avchd file just a different extension. If you simply change the extension it should work perfecly.One thing though: 5DtoRGB doesn't read m2ts right now.
Thanks Kholi !!!
Any chance we could see the raw frame before 5DtoRGB by chance?
Cheers,
pete
It shouldn't. Try turning off Live view and Movie. Treat it like your about to take a still - verify by looking through the 5D optical viewfinder. Switch the aperture to f22 then detach the lens while the camera is still on. And hold the lens up to the light. It should be wide open.
Nope, the lens was still f/22. It went wide open when I attached it back to the body (a 60D), then when I hit the "Movie" button, it shut back down to f/22.
EDIT: Okay, so it was set to Live View and movie mode, but that's just how my camera is set. Still goes that you don't need the DOF preview button step.
GH2 | QV9b | Standard -2-2-2-2 | Zeiss Ultra Prime 50mm @ 4~5.6 | ISO 160
720/60 | QV9b | Standard -2-2-2-2 | Zeiss Ultra Prime 50mm @ 2.8~4 | ISO 160 (I think)
Some random stills from work. Didn't light this one.
Banding occurs too much at this ISO
These lenses are too sharp for this camera, first time I've seen aliasing pop up (not as obvious as canons but there)
More coming anyway. xD
