Cineform Neoscene Question???
JerryB
I finally download the trial version of Cineform Neoscene to give it a test (a little late in the game on this, but have been editing in Vegas native with little problem till now).
Does Cineform Neoscene export audio as well as video, if so, how is this done exactly? I can not seem to figure out how to export the audio with the video. I've researched a little and not finding the answer yet (I'm sure it's out there) so I figured I would just ask and hopefully some one has a quick answer.
Thanks!
Yes, Cineform products produce normal video files (avi or mov) with both a video and audio stream. You say you are "exporting".... I assume you mean you are transcoding avchd into avi or mov. If so, the problem may be that you lack an ac3 decoder - if you go to the Cineform website tech support area I believe they address audio issues in their FAQ. Otherwise, post on the Cineform forum at DVinfo.net or file a trouble ticket - they are a very responsive company.
Yes... I had to go get this one: http://ac3filter.net/projects/ac3filter
CORRECTION
I must have had Vegas 10 open when I installed the filter. After closing it and reopening it I am able to see all the audio. Simple troubleshooting always works! Just thought I'd write it out instead of delete in case anyone makes the same mistake as I.
Thanks AGAIN
