Cine V scene file no audio HVX200A
Jon Fulton
I lost all audio input when using the Cine V scene file. I have initialized the file of course back to its default setting.
I can get the audio back if I change the operation type to Video instead of the default of film. This never happened before. Any ideas as to why this is happening?
Jon
solved
solved
forcing the Initial scene file does not reset the Frame Rate. I had the scene file set to 24Frames, and when I force the Initial it doesn't reset the Frame Rate to default.
Thanks.
The camera is not used. I fixed the problem by manually resetting the Frame Rate which I had assumed would have been reset when I forced the Initial scene file. Odd quirk.
