Hi,
I recently purchased a SmallHD 502 to use as a replacement monitor for my FS7. It appealed particularly as it enables me to apply a LUT while still being able to view the waveform but a couple of things have left me a bit confused.
In order for the FS7 EI switch to affect the appearance of the footage being viewed on my SmallHD 502, I have to turn on the Rec709 (800%) LUT for SDI2/HDMI in my FS7 menus rather than on the 502. But this means that the Waveform on the 502 begins to read the LUT values rather than the underlying Slog values.
And if I turn on the Rec709 (800%) LUT on the 502, then the 502 waveform will read the underlying Slog footage but when I'm deliberately under or overexposing the image being viewed through the LUT will be over or under exposed too.
So, I found Alister Chapman's '709 exposure compensated LUTs' and added them to my 502. This means I can view the waveform on the 502 as it reads the over/underexposed Slog footage but I can use one of the exposure compensated LUTs so that the footage looks correctly exposed on my 502.
This is the way that I'd like to work as it means I'm still monitoring what the Slog footage is doing while viewing the footage through a LUT that makes it look correctly exposed. However, can anyone tell me what the six Slog2 and Slog3 values are for 90% white when overexposing and underexposing to one, two and three stops?
Or is there another better method of using the SmallHD 502 with Cine EI that I'm completely missing? Perhaps it should be the six Rec 709 (800%) values for 90% white when oxerexposing and underexposing to one, two and three stops that I should be looking for? That way I would still be able to use the EI switch on the camera itself...
Thanks!
Thanks!
