Doug Jensen
Carbonite Member
I'm doing some tests of custom Scene Files vs. Baking in LUTs in Cine EI. The idea is to find settings that will provide a "ready-for-broadcast" look right out of the camera with virtually no grading. Obvsioulsy, if you're going to grade anyway, why burn in a LUT, right? So the premise is that no grading will be done to the footage. WYSIWYG.
Before I can do the comparisons properly, I would like to get a consensus (if that is possible) on what the correct exposure should be for the LUT I have posted below. It doesn't matter right now WHAT the LUT is, I just need some opinions on which of the four exposures looks best . . . if any. I will then use that exposure in the rest of my testing. Why? Because I don't want to have to shoot a bunch of test shots at different exposures, or have someone say the tests are no good because I didn't expose the LUT right. So which one of these do you like best? Now is the chance to chime in and help. If you had to choose one of the four options as your FINAL look, which one would it be?
****** EDIT ********
I HAVE DELETED THE FIRST VIDEO THAT WAS POSTED HERE.
PLEASE SEE POST #25 IN THIS THREAD
http://www.dvxuser.com/V6/showthread.php?335147-Cine-EI-LUTS-and-Custom-Scene-Files/page3
They are all the same LUT, just exposed differently.
Please let me know your thoughts.
Doug
Doug
