SOLD Chrosziel AC-204-01 Studio Rig Cine Follow Focus System
Status
Not open for further replies.
dp90068
As new, never used on a shoot, focus wheel never been marked on. Focus wheel switchable left or right side. Can be calibrated for still lenses without focus stops.
$2542 on B&H plus Chrozeil Focus Drive Mod .08-36.8mm $108 = $2650 new - - selling for $2150
For Canon C300, Canon C500, Sony F5, Sony F55, Arri Alexa, Arri Amira, Red, etc... mounts on 15mm rods
The Chrosziel Studio Rig Cine Follow Focus System includes a handwheel with a double-sided connection, a scale, and a focus lever. Thanks to the fluid damping module, gear units, and bearings with low tolerance, the system offers smooth and precise focus moves and is capable of play and jerk-free focus even for permanent direction changes. An adjustable range of 200º from close-up to infinity is usually found on video lenses, fixed focal length prime lenses, and cine-style lenses. By rotating the hand wheel, you can easily adjust the lens focus ring approximately 100-145º between close-up and infinity. The Studio Rig Cine Follow Focus system's easily mountable gear unit extends the angle of rotation of the video lens while additional adjustments can be made using gears of various diameters.
Includes a handwheel with a double-sided connection, a scale, and a focus lever
Fluid damping module, gear units, and bearings with low tolerance allow for smooth and precise focus movement
Capable of play and jerk-free focus even for permanent direction changes
Handwheel rotation allows you to easily adjust the lens focus ring approximately 100-145º between close-up and infinity
Easily mountable gear unit extends the angle of rotation of the video lenses and additional adjustments can be made using gears with various diameters
Status
