Nice looking footage Dan. Any info on when these cameras will be available? Are there also 16mm and 35mm versions?
Got an e-mail today from Kinefinity with the following info in regards to the KineRAW-S35:
1. KineRAW S35 pricing is around USD 6K~8K as net price.
2. It will be launched in China Mainland at first in coming April. For other countries, it comes a little bit late, maybe later in 2012.
3. Sample footage and results will come from January.
I uploaded the second lens test demo reel, #B1 (B1B), for the Kine-RAW-S8p (tm), here is the link,
http://vimeo.com/35148088
I'm working on the third reel today, its the 1828x1556x12bit@24fps anamorphic lens "Panavision" (tm), Cineon (tm), Celco (tm), mode for anamorphic format like used in 35mm wide screen movies. I wrote a new command in my de-Bayer program DANCINEC.EXE (tm) to copy the DNG frames from the SHOTS folder that holds the shots in the camera to my program's edit structure for processing. That should make things more automated, and then the workprint can be made easier. I have it copy the in camera WAV recording for the in camera audio to my programs audio track folders T001 and T002 to automate that step as well and keep things from getting lost or mixed up. So doing these reels helps me see where there are bumps in the workflow that some more code can smooth over etc.
About the prices, last I heard the S16 was half the S35 and the S8 was one forth the S35 about so that might work out,
S35 = 8000 to 6000?
S16 = 4000 to 3000?
S8 = 2000 to 1500?
But who know what the RMB to $ exchange rates could be by the end of 2012, as the dollar falls the prices would need to be adjusted I might think?
S35 = 8000 to 6000?
S16 = 4000 to 3000?
S8 = 2000 to 1500?
I forgot to use the right tags to show the player before, here is the player showing,
I edited the previous post, but in case people don't see that change I put here also.
Since the link does not show the player unless I am signed in, here is the non player link,
Dan, when will this cam be available for purchase?
