Cheap, Steady Handheld -- Or: BUY A TRIPOD
Kholi
Section Moderator
Never thought I'd be the one to say this, as I HATE being locked down... but, please....
Buy A Tripod.
If you can't afford to get a really good one that'll let you fluidly pan and tilt, buy a cheap one that'll at least hold the camera steady. The handheld stuff is just overboard now, and not because it's handheld, but because it's very poorly executed.
Jitters are killing footage. It was one thing when this all first started, but there is so much knowledge out there on how to stabilize your image that it's bordering sloppy to see them.
To this effect, I even followed my own advice and took advantage of the sales this Holiday and bought a crap $99.99 still photography tripod that's heavy enough to do some locked down shooting. And I HATE being locked down!!! I haven't ever purchased a tripod before but it's a MUST. At least it'll allow me to stay locked down when needed, and anything more I can rent.
Please... get tripods or find ways to stabilize your image.
What's that got to do with handheld, though?
That's a 300mm Clip and it was achieved with this:
picture.php
picture.php
The model's a SLIK PRO 400DX, if you can't tell by the last photo (taken with an iPhone, sorry) it's simply been flipped upside down. By taking the center column out and putting the tripod plate/head upside down, I've created a multitude of options for body contact AND I've kept the legs out of my path of operation.
There are so many different ways you can hold this thing it's ridiculous, and most of them are plenty efficient for operation. Better still, it takes about ten seconds to flip the legs back and lock them for "normal" tripod use. AKA the Locked Down Shot.
It works because the legs offer a certain amount of tolerable weight, and ALL of that weight is redicreted to your BICEPS instead of your FOREARMS and WRISTS. The body contact points are as you please, and you could even hold two of the legs at once. Or, you could hold the center column right beneath the camera, or "Grab it by the throat" and use your other hand to focus.
Works pretty friggin' well. So well that I may not be using my 14lb rig very often, as it's a doozy to carry around. Especially travelling!
It DOES take practice to get the handheld down, but it only took me two days with no external monitor to get it up to 300mm comfortably.
Another really great use is walking with it. If you've got a 17mm and below, it's pretty decent for a cheap, no-money option as far as walking goes. I'll have to get some footage up but I'm sure you can test it out yourself.
It doesn't replace something like a Glidecam 2000 Pro (I need to get one of those asap) but it's a decent interim until you can afford to drop three-hundred (300.00) on one.
So, go to your local camera store and haggle yourself into a "crappy" tripod and try it. You can always return it!
bowing down to your ingeniosity as the results speak for themselves.
can't wait to try that out to see if that magic is transferable to my shaky hands
Kholi,
Thank you, thank you, thank you.
I am currently saving for a Cinevate rig, but this made my day! I popped on my 200mm and tried some handheld with your idea/tips and it worked amazingly. Thanks for the great idea.
Dang! absolute jello killer... back from brief test with unstabilized Sigma 70-200mm and stunned at how this thing rocks steady.
the reverse foamed legs are nice to hold indeed allowing a variety of body contact and postures as you said the possibilities are just insane.
Cheers mate !
When I first read the post I was thinking "Why in the hell would Kholi ask about this":Drogar-Happy(DBG):
I do agree with insanely jittery handheld. I still like the look when done properly.
Well, there's a clear difference between Micro-jitters, which are spawned from the inability to hold the camera steady because of the light weight and improper balance versus intentional Handheld Aesthetic, which may drift, snap, jump to or shake.
The micro-jitters are much MUCH worse than any intentional handheld look. It looks like whoever's holding the camera is shivering to death.
I saw on videocopilot a while back a little short shot with the 7D shot entirely locked off, but added the handheld look in after effects and it looked really really nice. No jello or jitters, and the hand held effect looked very realistic and aesthetically pleasing.
So this was my first go at it, found a better way to hold the setup afterwards..but was out of light.
Doing some more tests tomorrow and going to do some more extended pans.
I also always do that for static tripod shots or motiongraphics. It's one little expression and takes no time to add, you can make it a nervous handheld or hardly noticable movement, just to take away that dead tripod feeling.
Another thing that should improve a stable image with Kholi's tripod trick is to find the right balance point where to hold it, like this guy demonstrates
http://www.youtube.com/watch?v=T1aPbwcqquk
lol.... you guys may run in to the occasional - "Why are you walking around with your tripod upside down??"
this pic kinda says it all... I couldn't figure it out at 1st, haha..
picture.php
VERY smooth for 300mm seriously. I will say this though, when moving the camera that much, there is a lot of skew in the image it appeared. Do you fix this in post? I tend not to move my camera in pans or whatever too fast because I had seeing the slant so much. Wondered what you all thought of that issue?
It's only an issue for me if I have to track stuff in post. Otherwise, I think we (defined as User-Heads) are the only ones that really care.
So, no, I don't even bother tampering with it. If it's there, it's there.
Yeah, sometimes I wonder if I look TOO closely at the stuff I record. I became a video perfectionist without even knowing it :)
There is a scene in Crank 2: High Voltage with definite jello. I cringed. (And yes, I bet you cringed at thinking of watching Crank 2, but I enjoy absolutely stupid crazy films at times)
Haha! Yeah, if you watch movies and you start looking, nearly EVERY "issue" that we all harp about is present. Transformers has some of THE worst edge softness I've ever seen in a modern feature film.
Nobody in the theater cared when they were LOLing and enjoying themselves.
Not that it's bad to pixel-peep, either. It's what gets us the advancements in gear that we want. Just have to learn how to turn it off... something I'm still learning how to do.
Oh, and I didn't cringe at the Crank 2 mention. I know what movies are for, and I am certainly one to enjoy all sorts of mainstream fun. =D Watch it up!
So true. The funny thing, I never noticed this stuff before. Maybe if I just down convert everything to 320x200 and watch it from 10 feet away I'll never see ANY of the problems :)
Amen brotha. I hate, HATE shaky handheld shots. I am a ski videographer and I cringe every time I watch a shaky edit. I use my tripod (701 head with 190dbx legs) as a steadier for most of my shots and I still hate even the slightest jitter. Hopefully I can find a good wide angle lens when I replace my DVC30 with a t2i.
Hey great stuff Kholi. This is like a DIY fig rig at one tenth the cost.
Bonus is you might be able to attach useful stuff like mic, H4 etc
