FS5: CHEAP Mic Spacer Solution for Sony Cameras
Chadfish
After getting my FS5 camera I noticed that the mic clamp was a lot larger than my Rode NTG-3 shotgun, and that Sony's mic spacer was way over priced, so I found a solution that will cost you .44 cents. Normally I would use my Rycote Lyre shockmount that fits into Sony mic clamps, but on the FS5 they have added loose rubber to act as a sort of shock mount, which results in a very wobbly mic, especially when using my Rycote mount. This solution probably won't work on all mics, but it can help if you just want to put your mic in the camera's clamp.
