Cheap Canon EOS Lens Adapter - EX1
I seem to remember someone talking about a custom adaptor ring that will take Canon EOS lenses. But the focal length will change greatly. Something like a 200mm lens becoming a 1000mm lens (or something like that).
Is that what you want? Maybe for wildlife use?
Otherwise, you need to save your pennies and buy a 35mm adaptor with a vibrating or spinning ground glass and flip priszm. But even then, no one makes a way for you to adjust the apature on EOS lenses. Unlike Nikon, you can't manually adjust the f-stop. The only way to do it is to bring an EOS camera with you and use it to set the f-stop, then remove it and mount it to your 35mm adaptor. Not a great work flow. :(
Good call guys. I just wasn't sure if there was some magic solution that someone came up with. I know about all the expensive ones.
And no, not for wildlife, quite the opposite actually. I wanna use my 10-22mm :)
Guess I'll have to wait until I get my Scarlet later this year.
