Chad Nikolaus
As far as i can tell, you can only switch between Low, Medium and High with the switch on the camera. You can set those values in the menu. As far as i know, you can't dial the iso in smaller increments without going in and changing the entire default L,M,H settings?
If so, it's about the ONLY thing i don't like about the camera. I wish you could use the dial on the camera the same way you change shutter speed. I've only taken it out for a couple of tests today, and found myself changing the shutter speed more than the iso just out of convenience. Feels kind of wrong though. Wouldn't you want to change the iso in small increments to fine tune your exposure rather than mess with shutter speed a lot?
