You can record SLOG3 with an atomos Shogun on a FS700, but its a lot more noisy than SLOG2.
In the opinion of many, including my own, the newer color science is easier to grade and plays nicely. It was designed to have less shifts when pushed around but it's not to say you can't or don't get great results with the older color science either.
One trick with the old color science and shooting slog is to disable matrix on the camera if possible. This in itself I think is the single best thing you can do if shooting slog on a Sony camera with old color science.
I believe the only updates to the FS700 there's a chance of is if there's new lenses that need correction... Unless the update that gave it correction for the 18-105 is a universal one that will work with future lenses as well. Then there likely won't be any more updates.
The Atomos Shogun can record the FS700 to SLOG3. So if requested enough, CD should be able to implement that in the 7Q as well.
a) 18-105mm update is not universal, as lenses need different corrections depending on their designs
b) Sony FS100 sadly never got the 18-105mm update..... I would be surprised if the FS700 ever got an update for future lenses
I believe the FS100 just doesn't have the extra pixels available to perform lens correction.
