combatentropy
I would rather everything go to Thunderbolt 3. It uses the USB Type-C jack, can carry power, and is 40 Gbps. It can connect all of your peripherals, like mice, printers, USB drives. It can be your video output cable to monitors. In fact, some are saying that the monitor could be the new docking station. A single power cable goes from the wall to your monitor. A single Thunderbolt 3 cable from your monitor to your laptop. From your laptop, all of your peripherals are connected. Power flows from the wall to the monitor, then to the laptop, and out to its peripherals.
Camcorder accessories could all move to Thunderbolt 3. For example, an XLR adapter could connect to your camcorder with it, and both audio and power could flow through it. And it could work for all brands and models, given that it's an industry standard. As another example, all power adapters could switch to it, and so power and battery adapters would work across all brands and models. No longer do you have to find a match among a dozen barrel plugs.
The same jack, in other words, could replace all power, input, and output, for all devices: computers, camcorders, phones, you name it. No longer do you have to make sure you carry a power adapter for each device when you go on a trip. You just bring one or two USB-C cables.
