Multi-Media
Three days left on Ebay!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170648510093&viewitem=&sspagename=STRK:MESELX:IT
At this point, someone will take home BOTH for $75...
Check them out...
Looking to extend your range with the Panasonic DVX 100 or HPX 170 ?
These adapters are both made by Century Optics and provide PROFESSIONAL RESULTS. I have used them on commercials, museum, and corporate films... they are the real deal... not some cheap add on glass.
One is a .6 Wide angle adapter and the other is a Macro Close Up Achromatic Diopter. You can shoot Extreme Wide shots in Close quarters or fill the frame with Extreme Close Ups that have a shallow Depth of Field.
Both adapters have had both of their caps on when not in use for a specific shot and as a result... they are Pristine... No scratches, smudges, dust, or even signs of wear.
The Wide angle is made for the DVX100, but it will fit an HPX170 with an adjustment, and the Close UP Diopter has a 72mm thread, so it will readily fit either camera.
I have recently upgraded to the Panasonic AF 100 and all new lenses, so I sold my old DV camera and no longer have use for these fine optics. They retail for around $400 individually, so this is an unbelievable combo deal for some lucky bidder. I just want to see them put to good use. There is No Reserve on this auction.
Check out the links below... each adapter separately goes for over $400.
https://www.schneideroptics.com/ecommerce/CatalogItemDetail.aspx?CID=1076&IID=1723
6X WIDE ANGLE ADAPTER DVX
$490.00 EA
Stock Code: 0VS-06WA-DVX
Ideal for shooting situations in which zooming isn’t needed. The .6X attaches to the front of your video zoom lens for 40% wider angle of view and minimal distortion.
Partial zoom adapter, allows zoom capability from wide angle to mid-range when using the camera in auto focus mode.
Comes in our popular Bayonet Mount that attaches with a twist to the front of your DVX100 10X lens.
https://www.schneideroptics.com/Ecommerce/CatalogItemDetail.aspx?CID=1081&IID=898
72MM +2.0 ACHROMATIC DIOPTER
$430.00 EA
Stock Code: 0AD-7220-00
Availability: In Stock
Magnification: +2
Thread Size: 72mm
This line of advanced Achromatic Diopters provides video zoom lenses with more close-up range and magnification, while maintaining zoom capabilities — without compromising image quality.
Common single element diopters permit focusing at close camera-to-subject distances at the expense of image clarity, a pin cushioning effect occurs. Instead, Achromatic Diopters feature two highly corrected glass elements which minimize chromatic aberration and distortion, creating an image with edge-to-edge sharpness
Check them out...
$490.00 EA
$430.00 EA
Magnification: +2
Thread Size: 72mm
