Cases for DVX100/A/B
AdamHD6
I've been looking around at cases on the internet for the DVX and there are definitely quite a few options. Hard case,soft case,backpacks,bags,waterproof, etc. I personally like hard cases and want to get some opinions, Pelican is a really reputable company that makes hard cases and I think Storm does too which you then can get pick-n-pluck foam to fit whatever you want inside. But Panasonic also has an option for the DVX the Thermodyne weatherproof case. It goes for about 170 probably around the same amount as a Pelican case. It's yellow which can be a bit troublesome if you're trying not to attract attention to your equipment. But if anyone owns either, what do you think? EDIT: And if you can specify which model case and maybe what you fit in it.
