[FS: General] Cartoni P5MA1 P-50 Pedestal System, Master Head, P-50 pedestal
rockett
[TABLE="width: 1158"]
[TR]
[TD]
[/TD]
[TD]Cartoni P5MA1 P-50 Pedestal System, Master Head, P-50 pedestal
  • P-50 Pedestal
  • Master Fluid Head
  • 2 x Pan Arms
  • 5-Year Parts and Labor Warranty (Head)
    5-Year Warranty (Pedestal)
This System was purchased late 2009 for over $20,000 check the well known store in New York it is the same price today. buy it now for $9500 over 50% discount.
http://www.bhphotovideo.com/c/product/537179-REG/Cartoni_P5MA1_P5MA1_P_50_Pedestal_System.html
works as new there is small scratch mark on one of the legs and the rubber cap on the damping control is split other than these cosmetics it is in as new condition. This unit looks like new it looks as if it has not been used.
2 pan bars and camera plate included.
Cartoni has a 5 year parts lbr warranty on the Master head and the P50 pedestal System so you still have 18 months plus warranty on this unit.
Any questions contact me at 310 383-9848 or message me if you purchase unit i can deliver to NAB show April 9th in Vegas or within 100 miles of Los Angeles otherwise it will be disassembled and shipped freight at buyers expense it weighs 86 lbs.
Description.
The Cartoni P5MA1 Pedestal System consists of the P-50 Pedestal, the MASTER fluid head, and 2 pan arms. With a load limit of 48 lbs (22 kg), this system is targeted for Studio/OB work where mobility is necessary without any compromise in camera movements.
Designed to support cameras weighing from 10 Kg (22 lbs) to 30 Kg (66 lbs) the CARTONI MASTER combines a wide range of counterbalance capabilities with an outstanding fluid damping system.
The P-50 is a portable and compact pedestal for both studio and OB applications. Extremely stable yet relatively lightweight, its ideal performance is reached with camera/lens combination of around 100 lb (45 kg). The air-filled, one shot column is fast and safe to operate: the air can be set in manually or by compressor, and a safety air pressure valve prevents danger of over pumping.
Master HeadThe fully variable counterbalance system is designed to accommodate offset payloads of 30 kg (66 lbs) ensuring excellent performances at any tilt angle. The head comes equipped with two telescopic pan bars, illuminated spirit level and digital readouts for drag and counterbalance settings.P-50 PedestalPneumatic column for rapid, precise positioning of loads up to 88 lbs (40 kg), foot operated brake on each of the wheels, and pneumatic tires for OB use.
[TABLE="class: specTable, width: 0"]
[TR="bgcolor: transparent"]
[TH="class: specHeader Header, bgcolor: #C4C4C4, colspan: 2"]General[/TH]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Load Capacity[/TD]
[TD="class: specDetail, bgcolor: transparent"]66 lbs (30 kg)[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Trim Ring[/TD]
[TD="class: specDetail, bgcolor: transparent"]No[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Bowl Diameter/Thread[/TD]
[TD="class: specDetail, bgcolor: transparent"]Mitchell flange[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Steering Ring Diameter[/TD]
[TD="class: specDetail, bgcolor: transparent"]17.7" (45 cm)[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Minimum Height[/TD]
[TD="class: specDetail, bgcolor: transparent"]30" (75 cm)[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Maximum Height[/TD]
[TD="class: specDetail, bgcolor: transparent"]55.1" (140 cm)[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Weight[/TD]
[TD="class: specDetail, bgcolor: transparent"]86 lbs (39 kg)[/TD]
[/TR]
[/TABLE]
[TH="class: specHeader Header, bgcolor: #C4C4C4, colspan: 2"]Post[/TH]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Stages[/TD]
[TD="class: specDetail, bgcolor: transparent"]1[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]On-Shot Stroke[/TD]
[TD="class: specDetail, bgcolor: transparent"]19.7 (50 cm)[/TD]
[/TR]
[/TABLE]
[TH="class: specHeader Header, bgcolor: #C4C4C4, colspan: 2"]Dolly[/TH]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Doorway Tracking Width[/TD]
[TD="class: specDetail, bgcolor: transparent"]39.4" (100 cm)[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Wheel Diameter[/TD]
[TD="class: specDetail, bgcolor: transparent"]4.5" (125 cm)[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Wheel Lock[/TD]
[TD="class: specDetail, bgcolor: transparent"]Yes[/TD]
[/TR]
[TD="class: specTopic, bgcolor: transparent"]Cable Guards[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
