Comes with:
Innerspace Cases CUSTOM flight case in grey w/black stripe ($1000 custom case)
1 right panhandle
sliding dovetail with large quick-release plate
pedestal + 150mm ball base adapters
The head is native mitchell mount, and comes with attachable 150mm and pedestal bases. Attach securely with 6 allen screws. You can see the 150mm base attached, and the head mounted on a 150mm sachtler tripod.
Here's some product info:
The MK2 can counterbalance a wide variety of cameras--from the smallest HDV camera to a fully loaded RED, ALEXA, F65, or C300 system. Its counterbalance system is an evolved version of Cartoni's "wing" system, providing superior performance throughout the +/- 90 tilt range, with perfect stops at any angle. The frictionless variable fluid modules provide a wide range of fluid drag for perfectly smooth and precise movement, while the ergonomic, user-friendly knobs are conveniently located and easy to reach.
The MK2 also features a flat Mitchell standard base and an available 150mm bowl converter to make the MK2 suitable for all leg options and dollies. The head is supplied with two telescopic pan bars, standard quick-release sliding camera plate, (Eurostyle plate optional) illuminated bubble level and digital readouts for drag and counterbalance settings.
1 right panhandle
