Nightwalker
I'm using premiere pro to capture and edit video, shot by dvx102b.
I had tried matrox dv codec. And now, when i right click -> properties, of captured dv Avi file, i see that, it has "Video compression: DigiVCap"
I searched the internet and according to that, this is matrox codec.
Premiere selects it as default dv capture codec... (at least i think so.. Because there isn't such a configuration. You can not change or look in to details of capture codec if you choose "dv pal".
Which codec i should set as defalt dv codec for best compatibility and quality with my dvx102b? Also, does this matrox codec create, or can it create, visual artifacts, bad re-compression, loosing color details, or any other problems?
Can it be effective on compressing red channel and can it be the reason of the more visible saw-tooth or stair-step effect, etc?
Thanks for sharing your experiences.
Best Regards.
Best Regards.
