Capturing 24P
Ross Craig
I just shot some footage with a DVX 100A in 24P normal (F5). I am totally confused about how to go about capturing it. Do I remove the pull-down? Do I need a 24 fps timeline? My final product is DVD, but I need to do dailies for the web.
Also, can I do a 24 fps DVD in iDVD?
Thanks.
Steve (c/o Ross)
What software are you using? If you shot in 24pA, then you need to use Advanced Pulldown removal, if you just used 24p, then you should use normal pulldown removal. If your going to output to DVD and web, you might as well use a 60i timeline, don't waste the time for pulldown removal.
