Capture to PC with Firewire
GoldenCam
Hey guys, I want to capture directly to my computer using Adobe Pro 2.0 with firewire. I tried this setup and its not recognizing anything. Any suggestions to why it isnt working and any tips on capturing to PC? Thanks.
PC Spec
Dual 4400+
4gb ram
800gb memory
You could capture DV, but only DV. Premiere Pro doesn't support any other mode from the HVX.
If you want to use the HVX with Premiere Pro you'll have to get Raylight or CineForm. With those you can't do live capturing, but you could record to the cards and then use Raylight or Cineform to convert the files into a format that Premiere Pro can understand.
Or, you could spring for a Matrox Axio system, that'll give you full functionality with Premiere Pro and the HVX, but it's not inexpensive...
