Caprock 2.0 / 7D
ROCKMORE
Has anyone done tests with the Caprock 2.0 on subjects like people with thin rimmed glasses to see how the filter will perform in a standard interview?
If so could you post some before and after clips.
The problem is, the filter will perform differently at different focal lengths. The ideal situation would be to find out which filter works at each focal length and then use the appropriate filter. But that'll get expensive.
Have you tried the Soft/FX filters to try to reduce the moire on things like thin rimmed glasses? Even if I have to loose some of the sharpness on extreme problem shots that I run into, It's a better option than the moire.
