Can't see transferred clips
NICK ASH
Ok, so I used the USB cable from the HVX200 to my PC and I had the settings adjusted correctly as the files transferred to the computer. However, if I click on the P2 icon at the bottom of the screen and then click on the files in the window....nothing. So, I opened up "My Computer" and found the files there but when I clicked on them and tried to view them they won't play. I am stumped...
think I found the problem
I read up on this and found that one of the p2 slots is formatted for the mac. My question is where are the cancel buttons and the battery level indicator button?
How to put a P2 Store into Mac-compatible mode:
To change compatibility mode between Mac and Windows: 1. Connect USB cable between P2 store and Mac or PC, and then turn on P2 store. 2. Make sure USB LED (D) lights. 3. Press CANCEL button (A), Battery level indicator button (B) and HDD capacity indicator button (C) simultaneously for more than five seconds. 4. The color of USB LED (D) is orange for Mac, green for Windows. NOTE : If you follow the instructions in order, the P2 store will not change modes correctly. The correct sequence is to first press and hold the HDD Capacity ( C ) and Cancel buttons (A), THEN add the Battery Check Button (B), now hold all three buttons for 5 seconds, the mode will change reliably from PC to Mac or back to PC. Doing the procedure in alphabetical order will produce hit-and-miss results. As mentioned in the note, it is necessary to connect a USB 2.0 cable to the computer or the USB mode LED will not light and you will not know which mode you have selected.
