can't get my AF100 to work with ScopeBox via SDI and Matrox MXO
So I must be doing something wrong. I can't get what my AF100 is seeing to show up in my ScopeBox application. I have my AF100 connected from its SDI port out to my Matrox MXO device and then to my MacBook Pro via the DVI adapter port.
Is there a setting I'm missing on my AF100??? I have SDI out set to on.
But my only choice available remains iSight in ScopeBox, all other choices are shaded grey. Is this because I'm running the trial version??? I thought the trial version was supposed to operate just like the real thing for 15 days.
Hi Nicholas - do you have an MXO or an MXO2? The MXO is an output only device - it can't be used to feed video in to your computer.
If you have an MXO2, it should work fine, but since you mentioned the DVI port, I suspect you're using an MXO.
-Colin
