guys, im using my m2 adapter with my dvx. is it possible to mathc the footage from no adapter to shots with the adapter. also, is it better for me to shoot 24p, 30fps or 60. my output source is onto my laptop.
The adaptor won't be as sharp as the naked lens so just turn the detail level up a bit when the M2's on. And when you don't have the M2 you can still cheap DOF a bit if you need it by having the camera further away and going as telephoto as you can/want.
If you want it to look 'filmic' you'll want 24p if that was your question.
When you do the Color Correction it should come together alright and you can always sharpen/soften a little in post if need by.
