JoeJITSU
Canopus Edius Neo Booster 2.5 Video editing software
I have Brand New Disk and code. Please SERIOUS ONLY!
Will ship in U.S. only.
$150
PM me
nfo:
EDIUS Neo 2.5 is unique in that it allows real-time video editor to work with any combination of supported formats in their original quality and resolution. With EDIUS Neo users can mix and match is being performed on the same format, codec, resolution, scale, working with with the native quality of the material in real time.
Features:
AVCHD (Advanced Video Codec High Definition) is a codec for recording and playback high-definition video. This format allows HD video recording on DVD discs, memory cards SD / SDHC, and hard drives. AVCHD format is also compatible with Blu-ray discs and can be used for authoring and distributing HD video.
One of the features of Edius Neo 2 - Working with video in real time. Once set the project settings, you can upload videos in any format, and the program on the fly, converts it into a necessary, change if necessary, aspect ratio, resolution, frames per second and other preferences. This Edius Neo 2 does not waste time re-encoding video. Show filters superimposed on video, transition effects, titles and other effects, too, is performed in real time. Quick work program is provided through support for multicore and multiprocessor systems. Already in the process of downloading the program analyzes the system and displays information about the number of processors, as well as support for SSE and MMX.
EDIUS Neo 2 - is a powerful tool for non-linear editing, bearing features such as multitrack editing, simultaneous work with HD and SD formats in one project, overlay titles and DVD-authoring.
What's new ?
Systems Requirements
Intel or AMD CPU with a 3 GHz processor speed or faster (multiple CPUs and / or multi-core CPUs are recommended. SSE2 and SSE3 instruction set supported)
- 1 GB RAM (2 GB or more recommended)
- 5 GB of hard disk space is required for installation (including third-party software)
- Drive with ATA100 / 7,200 RPM or faster is necessary for video storage (RAID-0 is recommended for HD resolution editing)
- A graphics card supported by Direct3D 9.0c or later, and PixelShader Model 3.0 or later is required
For SD editing: 128 MB or larger required, 256 MB or larger recommended
For HD editing: 256 MB or larger required, 512 MB or larger recommended
- Sound card with WDM driver support is required
- DVD-ROM/Blu-ray Disc writer, DVD-R/RW or DVD + R / RW drive is required when creating Blu-ray Discs or DVDs
- Free USB port (1.1 or higher) is required for security key
- Windows XP Home or Windows XP Professional (SP2 or later, 32-bit)
Windows Vista (SP1 or later, 32-bit or 64-bit), including the following operating systems:
Windows 7
$150
PM me
nfo:
Features:
What's new ?
Windows 7
