Canopus ADVC A/D converter - Elite BVP-4 Plus Processor
Tommy K
Have to sacrifice for project funding. $300 for both! If you want to make DV even better, run your tapes through the BVP-4 Processor and see the resolution increase! Great for transferring and saving from analog tapes. Use the Canopus ADVC analog to firewire convertor to upgrade to digital video.
ELITE VIDEO BVP-4 BROADCAST VIDEO PROCESSOR PLUS
Elite BVP-4 Broadcast Video Processor PLUS. This unit is in great working and cosmetic condition. It comes with power cord. Here are some of the amazing features of the BVP-4:
- Accepts either NTSC composite or S-video inputs. Outputs are NTSC composite and S-video, and both outputs are active at the same time.
- Herringbone noise filter reduces noise caused by electrical interference.
- Split Screen allows you to instantly see the "before and after" when you make changes to the picture.
- Color Level lets you take away any amount of color you desire, enliven dull video or prevent color smear. You can even go to black and white.
- Fleshtone automatically restores reddish tone skin back to natural tone that it is in real life. Great for 1-chip or 3-chip camera images.
- Tint Adjustment gives you 360 degrees of full color correction. Easily fix video whose color is wrong without affecting the blacks or whites.
- Point to Point Luminance allows you to brighten your signal without losing contrast. Get up to 9db gain in your signal! "Gain up" without grain up!
- IRE Adjustment lets you bring up the video level of the whole screen. From black to white and everything in between.
- Resolution Boost gives you up to 90 lines more resolution with RTX enhancement technology.
- Black Restore lets you restore the black to original jet black without affecting the values of the other colors.
The following improvements are incorporated into the BVP-4 PLUS:
- The BVP-4 PLUS has 1200 lines of resolution.
- The BVP-4 PLUS has self-adaptive resolution - which means that once you dial in the amount of resolution boost you need, you simply let the BVP-4 do the rest. If figures out how much resolution enhancement you need based on the values of the video passing through the processor.
- The BVP-4 PLUS has a digital gamma compensator circuit - This circuit is controllable by a switch on the back of the BVP-4 PLUS. Turn the switch on when you have an input from a digital camcorder such as the Sony DV1000. This feature will give you a greater degree of highlights and detail in the shadow and dark areas of the picture. This detail can be lost due to the compression ratio systems of the digital format. The circuit in the BVP-4 PLUS helps get that detail that was lost.
