scorsesefan
Thinking out loud here. I'm considering a preorder. If I do, it will be the first time I've done it. The small form factor, DGO, NDs, Canon color, and 10-bit XF-AVC to SD cards would make my life a lot easier. Just being able to shoot clean ISO 3200 would be super helpful. Also, being able to monitor C-Log2 in-camera. Plus, I already own two BP-A60 batteries and a dual charger.
Selling my C200 and both C100s and replacing them with two of these is also something to think about.
Hesitations:
- The DPAF example in the lengthy CVP overview was not impressive at all. I need to see a better example.
- I have a decent selection of EF lenses and don't own any RF glass. The Canon focal reducer looks great but reducing the DPAF to 60% of the sensor is a no-go for me. I'd probably get the EF-RF adapter with the control ring. Does it also reduce CA and distortion? Maybe I need to factor in the cost of a Holy Trinity set of RF zooms. Not cheap.
- Mounting points. There aren't many. The Accsoon CineEye and a Sennheiser G3 receiver are almost permanently attached to my C200. Adding a cage kind of defeats the purpose of the smaller size.
- I'm heavily invested in Vinten fluid heads. I don't even know if they make one that will work with a 3.5-4lb camera.
- This all would require a major reshuffling of my gear. I just did that in 2019 with the C200, telling myself that I wouldn't do it again for at least 5 years.
IF you are OK with the form factor I would pull the trigger. Personally, I am not a fan of the "fat" DSLR. I do a lot of handheld work and it looks like the c70 is going to be a bit of a PITA to shoot with held against your body as a point of contact. In the pics it looks as if the LCD doesn't clear the body when it swivels up (looking down on the screen). A cabled LCD that could be placed on the top handle would have been better. There's also the client perception problem with smaller dslr/cinema cameras. The C200/FS7/FX9 etc. have the "look" of a professional camera. Not an issue if you're using it as a B cam...
