Canon XL H1 s camera BRAND NEW - 6500 obo
KUTrojan
I am looking to sell my Canon XL H1s digital camera. This is the NEWEST version of the H1 series that canon came out with this past June. Amazing camera and picture quality with the "jack pack" of allowing sync tc as well as PURE HD output with an HD/SDI in/out jack. Specs are below.
I won this camera but unfortunately am not a cinematographer or camera operator, but want it to go to someone who can and would use it. Very professional camera to make any type of films, commercials, or TV content. Retails between 7500 and 9k, looking for 6500 or best offer. Thanks
Overview
Exceptional Image Quality...Definitive Control...Professional Functionality
For more than a decade, Canon has brought industry-leading lens optics and image processing expertise to the professional market with the XL Series camcorders. In that time, leading videographers have come to rely on the superior image quality and ultimate creative control available to them through the XL Series' features and open architecture system.
The latest in that line is the Canon XL H1S HD camcorder. It has all the features that have made the XL Series a favorite of independent filmmakers, corporate and event shooters, in addition to broadcast and news markets. To complement these features, the Canon XL H1S has added an even higher level of customization options and capabilities which will make it an even more useful creative partner for the demanding professional.
Industry-standard connections and terminals along with a wider range of image control settings and options are combined with the new Genuine Canon 20x HD Video Zoom Lens III with Professional L Series Fluorite. To back up that superb lens are three 1/3" Native 16:9 CCD with 1.67M Pixels (delivering a full 1440 x 1080) and Canon's exclusive DIGIC DV II HD Image Processor. The XL H1S is the compelling choice for anyone seeking to produce the best in high definition video.
Specs
Digital Video
Power Supply (rated)
7.4V DC (battery pack)
Video Recording system
HDV: HDV1080i; DV: DV specifications
Two rotating heads, helical scan azimuth recording, (Consumer VCR SD specifications)
Audio Recording system
HDV: 2-channel recording MPEG1 Audio Layer II: (bit rate 384 kbps);
DV: 2-channel recording PCM digital recording: 16 bits (48 kHz), 12 bits (32 kHz, 12 bits selectable)
Image Sensor
(3) 1/3-inch Native 16:9 CCDs (1440x1080)
Total Pixels
Approx. 1.67 Megapixels each x 3
Effective Pixels
HD approx. 1.56 Megapixels (1440 x 1080)
SD (4:3) approx. 1.17 Megapixels (1080 x 1080)
SD (16:9) approx. 1.56 Megapixels (1440 x 1080)
Tape Format
Video cassettes bearing the MiniDV mark
Tape Speed
HDV/DV: SP mode 18.81mm/second
DV: LP mode 12.56 mm/second
Maximum recording time
HDV/DV: SP mode 60 min. DV:LP; 90 min.
Lens
Canon 20x HD Video Zoom XL 5.4-108 mm L IS lll
Lens Mount
XL interchangeable lens system
Focusing System
TTL-video signal sensing system autofocus. Manual focusing possible (20x zoom XL 5.4-108mm L IS III installed)
Minimum Focusing Distance
20mm (wide macro), 1m (entire zoom range): (20x zoom XL 5.4-108mm L IS III installed)
Frame Rate
60i, 24F, 30F
Minimum Illumination
60i, 7 lux (1/60 shutter speed); 30F, 4 lux (1/30 shutter speed); 24F, 3 lux (1/24 shutter speed)
Genlock Terminal
BNC Connector (input only)
HD/SD-SDI Terminal
BNC Connector (output only)
SD-SDI: compliant with SMPTE 259M (video std.), 272M (embedded audio std.), RP 188 (LTC) (timecode std.)
HD-SDI: compliant with SMPTE 292M (video std.), 299M (embedded audio std.), RP 188 (LTC) (timecode std.)
Timecode Terminals
BNC Connector (input and output)
Component Terminal
1080i/480i supported
Image Stabilization
Optical (VAP)
Filter Diameter
72mm (20x HD Video Zoom XL 5.4 - 108mm L IS III Lens)
Viewfinder
2.4-inch widescreen, TFT color EVF/LCD Monitor, approx. 215,000 pixels
Microphone
High-performance stereo electric condenser microphone
Recording Media
SD/SDHC, MMC
DV Terminal
HDV/DV Special 6-pin connector (IEEE1394 compatible); both input/output
Output Levels
-12 dBV (with 47-kohm load, 1 Vrms output level setting and -12 dB full scale)
S-video Terminal
4-pin mini-DIN; both input/output
Audio Terminal
(a) Also serves as RCA pin jack (white/red, L/R) both input/output (2 systems)
(b) XLR 3-pin jack (2 systems); switchable between MIC/LINE
Microphone Terminal
3.5mm stereo mini-jack
Operating Temperature range
32 - 104° F (0 - 40° C)
Dimensions
8.9 x 8.7 x 19.5 in. (226 x 220 x 496mm)
Weight (not including lens and battery pack)
5.6 lbs. (2540 g)
Weight (fully loaded)
8.8 lbs. (3995 g)
Key Words: Canon, XL, H1, H1s, Panasonic, Sony, EX1, HVX, DVX, HDV, High Definition
